Bonjour à toutes fins utiles , vous trouverez ci joint les références de toute la visserie ( wishbone, amortisseurs )
Extrait Pistonheads
https://www.pistonheads.com/gassing/topic.asp?t=1343152
Hi Guys as promised - The Definitive List:
1. Front N/S & O/S
Shock absorbers - 1/2" x 3" UNF 4 off
Top Wishbone Chassis mount - 7/16" x 3" UNF 4 off
Top Wishbone Hub mount - 7/16" x 3" UNF 4 off
Bottom Wishbone chassis mount - 7/16" x 3" UNF 2 off, 7/16" x 5" UNF 2 off
Bottom Wishbone Hub mount M8 x 60 6 off
2. Rear N/S & O/S
Shock Absorbers top - 1/2" x 4 1/2" UNF 2 off
Shock Absorbers bottom - 1/2" x 3 1/2" UNF 2 off
Top Wishbone Chassis - 7/16" x 3" UNF 4 off
Top Wishbone Hub mount - 7/16" x 3 1/2" UNF 2 off
Bottom Wishbone Chassis mount - 7/16" x 3" UNF 2 off, 7/16" x 5" UNF 2 off
Bottom Wishbone Hub mount - 7/16" x 3 1/2" UNF 4 off
NOTE: All High Tensile Steel. Quantities shown are for both sides either front or rear.
To buy fixings give the following a call:
a) ARUN Fastener Company (aka Classic Nuts & Bolts) - 01243 551484 - good old fashioned talk to a knowledgeable human being service.
b) Kwikfast - 01376 502072
Regards, Pete
Visserie liaison au sol
Re: Visserie liaison au sol
Merci!
Effectivement cela peut être utile si la visserie se montre récalcitrante lors d'un démontage
Merci pour les infos
